A-4
Are you pulling it or the yard? Are you doing the rebuild or are you jobbing it out? Take pictures of it from many angles. If you're pulling it, take everything off that you can, starter, carb, alternator, coil, wires, water pump/s, etc. before removing it from the boat. Make sure that the engine mounts are free and your coupler is loose. Put everything removed, including fasteners, in labeled plastic bags and label all of the wires. Being very organized now saves a lot of time and effort later. If you're tearing it down follow the same advice. Each individual part disassembled goes in a bag or envelope marked from where it was removed, even remnants of gaskets.
