Recently purchased a 1969 Ericson 23 with a thru-hull rudder assembly. The tiller mount fits into the thru-hull fitting and has, incorporated into one piece of metal, two "pin mounts" (small holes for a bolt to slide through) for the tiller. One of these has been broken off (as can be seen in the photo).
Does anyone know where to find a replacement part, probably the entire thru-hull rudder fitting? If not, what are some suggestions for repairing this?
Thank you,
Andrew
Thank you,
Andrew
