Time, Labor, Money...
There are 5 or 6 + boats in the last few years around our little club that have had a complete refinish of their hulls and decks. This involves removing (tagging, bagging, and pictures...)
all of the hardware. All. Yup, all.
:nerd:
As previously mentioned all holes are over-drilled & filled with thickened epoxy. Then any hardware relocations or upgrades are done. Windows and all exterior wood removed. Toe rails are normally removed, too. Many hours of fairing and sanding follow. Many.
LPU is applied after all prep work, followed by clear coating. Non skid done separate with "grit" applied. Finally all the removed parts are reattached with new sealant/adhesive. It's
quite a process.
Basically the boat is restored to new or near-new.
Even with the owner doing hundreds of hours of labor, it's still easy to have 60K into the final accounting. Budgets also rise every time you utter the phrase "while we're at it..."
These were all boats over 30 feet long, with owners that plan to keep them and use 'em for at least another decade... or until they get out of sailing.
Two were Cascade 36's that are now cruising Mexico, and then there is
Raindrop!
Another is a Jason 35 just home from a summer trip to Hawaii and back.
What with new boats in the mid-30's costing over 300K for quality ocean-capable design and construction, all these owners considered the rebuild a cost effective way to "start over."
Between the personal labor and the $ cost, you just have to be
real sure of what you want for your future. In all these cases the spouse was 100% on board with the idea and is an active sailing partner (and did a lot of the sanding, too).
If we decide to keep the Olson another 15 years... we may yet do something like that... depending on how long it takes to recover from our $$ current home remodel. :rolleyes_d:
Regards,
LB
