Bypasses = no pink stuff in tanks
Between our RV(pre-boating) and the boats, I found two issues related to water taste. We used the vehicles most weekends and then a few weeks consecutive per year. First, I drain the water tanks once a month. When I fill the tanks, I use the Aqua Clear additive. Second, I minimize the amount of antifreeze put into the system with none ever in the tanks. To minimize the amount of the pink antifreeze I use on our E34, I do some bypassing. I did the same setup on our E32-200 and it worked for 5 winters without any freeze-broken lines. By not putting anitfreeze in either the fresh water tanks or the hot water heater, I've found after a good rinsing, the residual antifreeze taste is minimal. I had a bad experience with blowing the whole system out with air once on a trailer I had, so I don't trust that anymore with one exception you'll see shortly.
For winterizing the tanks are pumped dry. In the case of the hot water heater, it is pumped dry, bypassed and then drained into the bilge with the drain stopcock. I use my fresh water intake bypass to blow air in to clear any residual water the short distance back down into the tanks. The last step is to feed the anitfreeze into the bypass between the water tank valves and the pump and run it until all fixtures pump pink for hot and cold faucets.
Spring commissioning involves simply reversing the bypasses, making sure the hot water heater drain stopcock is closed, filling the water tanks, and pumping away until every thing runs clear and taste is decent. Some people put the antifreeze in the hot water heater. When I did that in my RV, it took many flushes to get the taste out of the hot side.
I installed the commonly available hot water heater by pass kit. Once you get to the heater, installing the kit is easy. The problem is getting to it since it's in the forward end of the starboard cockpit locker and it's fittings closely face the head bulkhead. I meticulousy measured where to cut the rear head wall so the tank fittings were accessible. I carefully cut the hole (dremel) without severing the hoses and cables behind it and saved the wall panel removed. I made an overlapping mitered teak frame and attached it to the panel so it could all be reattached with some flush screws later.
Bypassing the fresh water intake side of the water pump was trivial on the E34 since PO removed the bow water tank to install an AC unit. The hose still led to the pump; I cut it off just long enough to insert it in my antifreeze bottle. Then pumping from it was done by setting the valves for the phantom forward tank. On the E32-200, I had to install a t-valve with a short hose for the antifreeze bottle.
It could probably still use some of the sanitizing procedures posted here. I'll try that this year. We don't drink from the water tanks. We use bottled water for that. To conserve drinking water on anchor we drink as much alcohol as possible instead.
-- neal
