Rocinante33
As I attempted to service the manual pump for the waste pump out, I found it to be beyond service. There is significant corrosion on the flanges and I am unable to remove several of the screws that secure the two flapper valves, even with an impact driver following a PB Blaster soak.
I propose to replace the pump with a Whale Mk 5. Has anyone else gone this route? It is constructed of acetal & glass reinforced polypropylene so it is more corrosion proof than the original cast aluminum pump body. It's cheaper, too. Defender has it for $113.
I could add a macerator pump instead, but it would be a long difficult wire run.
