Vtonian
E38 - Vashon
Bruce, I was using the 'Regular' model you show and realized immediately that it was necessary to be really careful how I applied it to get repeatable readings but was able to do that repeatedly, at least close enough to believe I wasn't dangerously overloading or under tensioning one. I was also skeptical about accuracy but allowing room for all the variables that might affect accuracy for any individual piece of cable, and that ultimately, it's going to be an eye/feel proof of the pudding anyway, it seemed like a pretty reasonable place to start for an indeterminate age rig with obvious issues and lots of room for improvement, especially for a novice.
One of my biggest concerns about this boat has been the potential corrosion around the base of the mast. What little I know about aluminum is that it's really strong, until it's not, when it very quickly becomes rubbish, sometimes without a lot of indication. I did clean and inspect that enough before tensioning to convince myself the mast has mostly a surface/paint issue but I had been concerned about whether tightening up the rigging might crush it. I've had corroded aluminum crumble in my hands and in fact, part of the pedestal base did just that on my last sail, going from a major crack in the flange to a pile of dust when I stepped on it one more time.
At the other end, I've also been concerned about the amount of rust staining around some of the stainless, notably the backstay chainplate. What little I know about stainless is, crevice corrosion can be disastrous and often the only indication might be that rust staining. Based on my oath to first, do no harm to this boat and second, sail it at least as much as I work on it, I didn't want to destroy something I might need to fulfill my sailing commitment this first season with her. But those issues will be stories for another day...
