Kif
This past weekend we wrapped our prop with a dock line and the stress apparently bent the strut and a bit later the prop shaft broke near the base of the boat. Guessing the bent strut pulled the shaft out of alignment which stressed it until it broke.
Starting to shop around for repairs. Curious of a couple of things from others here (based on questions I'm getting back).
- Strut is bronze right?
- It's pretty bent out of true and has some corrosion, time to replace yes?
- I was asked how it's attached inside and have not looked yet. Are bolts glassed over on the inside?
- Thoughts on gross repair costs (we are in the bay area). New shaft, probably new strut, cutlass bearing, stuffing box maybe.
- Any recommendations for where to go (we are in Berkeley Marina)?
