For anyone who has changed the fuel tank on 35-III ..
Is there a specific size / model that you used that did not require any modifications ? and / or ...
If you went custom - do you have a copy of the drawing you used (I'm not sure the 35-II drawing I have is accurate - and I no longer have the original tank to compare to).
I realize that I may need to go much lower than the original 40 gal. tank unless I go custom.
Any additional info / contacts would be greatly appreciated.
"Tenacious"
"Tenacious"
