windjunkee
My partner is on a first name basis with the guys at Moyer Marine. They ARE great. Most of the parts we replaced on our engine came from Moyer. Ultimately, A-4's are just glorified lawnmower engines so the systems are simple. We've had all sorts of interesting issues that you just don't expect - like when the engine almost immediately overheated on starboard tack (no, the water intake did not come out of the water). Or the backflow through the exhaust that allowed gobs of seawater into the engine when we were running in following seas (yep, we put a drain on our water lift muffler and that seemed to do the trick). The install of the new engine was ultimately the death of us. We took our time finding the replacement engine. We had a pro do the rebuild when it was out of the boat. It was putting the new one into the boat where everything kinda got hinkie.
When we bought VOR in 2004, it had the engine head off and there was water and rust sitting on the cylinder heads. We thought we had to do an immediate replacement, but a little encouragement from Moyer, a bead hone, a bunch of new parts and some trial and error and we had a working engine. Albeit we had reduced compression on the back two cylinders and we had to deal with other issues, but that little motor took us many places and got us out of trouble more than once.
So listen to the rebuild crowd. These engines last forever. However, once the interior barriers between sea water and oil were breached, we had to replace it. That old engine was toast. If you do replace it, be vigilant about the alignment. It is a bitch.
Jim McCone
Voice of Reason E-32 Hull #134
Redondo Beach, CA
Jim McCone
Redondo Beach, CA
