Final note: The best reason to go through the hoops of re-doing one's power system is that it forces you to understand what all the damn wires are there for.
Yes, I guess we all need to go through that, at least mentally. But the trip really soured me on all the electrical sales folks over selling all the complexity and capacity to bedazzled yacht owners who may not be starting with an idea of what they actually need and will use. Understanding acceptance rate of batteries and the charge rate of smart regulators is the key. But having gone through all that, I now realize that a couple of old 100ah flooded batteries, the old Motorola 50amp alternator and a 100w solar panel and regulator probably meets the needs of most folks if not doing air conditioning or induction ranges.Final note: The best reason to go through the hoops of re-doing one's power system is that it forces you to understand what all the damn wires are there for.
Now you're talking my language. Though it's a 200w solar panel, and I bring aboard a couple large capacity rechargeable Bluetti batteries for anything that requires AC on our trips.Yes, I guess we all need to go through that, at least mentally. But the trip really soured me on all the electrical sales folks over selling all the complexity and capacity to bedazzled yacht owners who may not be starting with an idea of what they actually need and will use. Understanding acceptance rate of batteries and the charge rate of smart regulators is the key. But having gone through all that, I now realize that a couple of old 100ah flooded batteries, the old Motorola 50amp alternator and a 100w solar panel and regulator probably meets the needs of most folks if not doing air conditioning or induction ranges.
That exactly describes my system after doing a significant rework 2 years ago. I also have dedicated start and house banks. All charging goes to the house bank and an ACR tops up the start bank. I replaced the common Off-1-Both-2 switch with a dual switch to keep the two banks separate. A Victron battery monitor keeps me informed on system status.But having gone through all that, I now realize that a couple of old 100ah flooded batteries, the old Motorola 50amp alternator and a 100w solar panel and regulator probably meets the needs of most folks if not doing air conditioning or induction ranges.
Nice! Fall, before we get snow and ice... is a great time to cruise the NW. Uncrowded docks and anchorages.All nice spots and usually quiet this time of year
We also have 4 AGM batteries. We bought the boat 16 years ago. The PO had installed a high output alternator a few years earlier. It is an AmpTech alternator. (I can’t recall if it is rated at 100 or 105 amps). We have had no problem with it using an external voltage regulator. I believe it is a good alternative to BalMar and possibly less expensive.What manufacturer do you all recommend keeping budget in mind?
I was recently measuring the space beneath the salon aft seat in my E38, where the PO had aslo put 3 of my size 31M 110Ah AGMs, and thought I should be able to *just* squeak a set of 4 in there, without too much renovation/innovation....When I installed my house bank of 4, 110 AGM’s do to room restrictions, i had to place one battery in the designated battery compartment near the engine and the other 3 are located beneath the salon aft seat...
Hi @Navman , I'm happy to know someone here cruises the calm water of San Domingo Creek, where I used to live, hunt geese, fetch crabs from pots and tong for oysters from the dock... Ah, those were good days. Find the old book, "Chesapeake Duke" by Gilbert Byron who build a little cabin on the creek. Just lovely.I’m at a loss.
Sorry I’m only seeing this now. N answer to your question, yes you can fit four batteries under the aft salon seat. I took a piece of 3/4” primed ply and placed it at the bottom an top of the stringer, screwed it down and due to the curvature of the hull and raking the floor up I got enough room for the four batteries. I then added the tie down straps and all was good to go. This freed up the space under the nav station seat which I use for all my flares, signal flags. And other safety items.I was recently measuring the space beneath the salon aft seat in my E38, where the PO had aslo put 3 of my size 31M 110Ah AGMs, and thought I should be able to *just* squeak a set of 4 in there, without too much renovation/innovation.
Are yours bigger? If theres any way you can stuff 4 in there, you could then wire them for balanced charging.
Pete, no it went directly to the starter battery. Hooked up by the P.O. I am changing that and having it go to the battery selector switch. I think that may have been a big cause if my issues. Sorry for the late reply. Thanks for the help!Wire size is as important, and perhaps more than distance as far as voltage drop. Doesn't your alternator go directly to a battery switch?
