I should add that mounting from the forward transom would be difficult if not impossible, as it’s virtually inaccessible...Nice setup, David. The checked out your installation pics. Lots of work! My 35-2 is a bit different. The rudder shaft is longer and also angled forward and I am auxiliary tiller mount in the cockpit, so there is lots of real estate to connect to. The engineering will be a bit tricky, however, as I would need to manufacture some sort of bridge/plate between the existing steering pulley mounts on which to mount the actuator at an angle perpendicular to the shaft... Would LOVE to see how any other 35-2s have done this before reinventing it!
Innovative approach with the G10. I've read recommendations against messing with the quadrant, but it looks like you distributed the load over the whole things, so I can't imagine why that would be a problem--so long as the actuator is aligned perfectly on the same plane... Now you've got me thinking...I suspect your 1970 E35 is very similar to our 1972 E39.
I don't have any pictures that show how I did it, but here are a couple that show the result. The 39 also has a forward tilting quadrant, so getting the alignment to a constant angle changing hull required a decent mockup. I built up a fiberglass and plywood structure on the hull to mount the hydraulic ram. And bolted a hunk of G10 to the quadrant to attach both the arm and rudder angle measurer thing.
The G10 on the quadrant allowed a bit of flexibility to the final through bolt position and avoided the cost of that expensive tiller arm that you can buy.
Loren,Wasn't there someone posting here fairly recently about acquiring a wheel pilot from http://www.cptautopilot.com
Given it's reputation for reliability, it might be an alternative to the more common Raymarine (former Autohelm) drive motor device.
Maybe.
