wheel pull +3 blade, off-center shaft
Hey we had a lot of wheel pull (to port) on our 1988 E34. I put the details in a late March 09 post I started:
late 80's E-34- prop shaft position,
which you may be able to get thru at this address, or go back thru Maint and Mechanical by the title.
http://www.ericsonyachts.org/infoexchange/showthread.php?t=7266&highlight=Slipstream
Long story short the pull seems to be due to off center shaft and prop (do you guys have this?) as observed out of water sighting forward from center (prop is 3/4" to port) and/or teh assymetirc rudder (which would tend to make this type of wheel pull if enough assymetry. See the other post as I cannot remember all the numbers. We did not try to move the shaft nor did we buy a new rudder. Did a bunch of other stuff instead! including replaced teh sterring cable as the one side was worn out, and the quadrat was cracked.
We did put a new 3 blade prop on to replace th old undersized 2 blade. We put a Max prop feathering prop on there. Got a LOT more power and similar wheel pull at the same speeds, no less. So I am dubious about the idea of a 3 blade helping the pull. OUrs pulls enough to get very tiring and I put a thick bungy on it when motoring. When we take it out of gear most of teh pull goes away, so I think it is the prop wash.
I suggest seeing if teh prop is on center and maybe if we are lucky WE CAN FIND SOMEONE WHO KNOWS IF ERICSON/PACIFIC SEACRADT INTENDED FOR THE SHAFT TO GO OFF TO PORT. No answers to that one yet in this quest.
Enjoy the windy season!
