We replaced the radio, antenna and coax last fall. (sorry, no photos). The job, which seemed pretty straightforward, turned into a nightmare with at least 5 hours logged at the top of the mast.
The mast doesn't have conduit running through it. It has foam plugs in at least two places. Replacing the antenna was the easy part. The bracket was already there and I simply disconnected the coax from the old antenna, unscrewed it from the bracket and screwed the old one in. For the coax, I cut the old one and stripped some of the cover off. Then, with the new one, from the top of the mast I twisted the wires and sheathing together and bound the joint with some tape. Then, my partner tried pulling the new one through the mast using the old one as a messenger. The problem came when the joint got caught up in the mast and parted ways. Now, we no longer had the old one in the mast and the new one was only a third of the way down.
We had to go buy a long fish wire. Then, from the top of the mast, we ran the fish wire down (this wasn't easy). We got the fish wire out from an access hole at the base of the mast and lashed a line to it using whipping twine. The line was then pulled back up the mast. Once it reached the top of the mast, I attached the new coax to the line, again using whipping twine for a very strong joint, and pulled the new coax back down. This worked, finally. I then liberally applied silicone gel to the connection and connected the coax to the antenna. It works fantastic, but the insides of my thighs were bruised for weeks because of all the time spent at the top of the mast holding on!
If I had to do it again, I would MAKE SURE, the joint between your old coax and new coax is strong. Twisting the wires together and taping them simply wasn't enough for the strain of having to pull the cable and that joint through the tight spots of the mast.
Jim McCone
Voice of Reason E-32 Hull #134
Redondo Beach, CA
