sailinggreg
Hi Tom,
Thanks for your simple and clear reply. This certainly seems to be my set up. You can see the smaller wires in the picture. I remember when I had an electrician on the boat he added a fuse on each wire just as you mentioned. Those small wires are even labeled so I will double check when I'm on the boat but I remember they go to the charger.
So I guess the boat yard did in fact move the red cable from the positive terminal of one battery to the other. I guess either since the battery was smoking they didn't want to leave anything connected to it, didn't want to leave the red cable just dangling, or maybe since they didn't know which one was battery 1 and battery 2 they connected both the red cables to the one battery to try and charge it and start the boat. Any thoughts on that?
Greg
Thanks Tom, Loren and everyone for the good discussion and info regarding batteries.
I installed my new batteries but still have a couple questions.
There is only one small wire going from my charger to the positive terminal on only one of the batteries. I even traced it back to the charger to make sure another wasn't laying loose someplace, but on my boat there only appears to be the one small wire from the charger to the positive terminal of one battery. (The two other small wires I recalled (and in the previous pic) go to the auto-helm and a USB power supply in the cockpit).
So, I went ahead and installed my batteries as described by Tom but with just the one small wire from the charger to the positive terminal of one battery. Engine started right up. To test, I drained the batteries one at a time (left a couple cabin lights on overnight), but one battery would only recharge to about 10 volts.
A boat buddy thinks that there should only be one small wire from the charger and looked in Calder's "Boatowner’s Mechanical and Electrical Manual (the bible? ), which said if one battery doesn't charge completely you should put the battery selector knob to BOTH. I did this and both batteries fully recharged.
Does this make sense to you experts?
I'd really appreciate further thoughts.
Greg
