Willpatten
Has anyone installed a below deck electric autopilot piston on a 38-200? If so, where did you put it?
Edson makes a tiller arm that attaches to the rudder post and is made specifically for below deck APs. It ain't cheap but seems to be the best alternative to me. I am planning on going to a below decks AP as my wheel pilot just doesn't handle the load in a quartering sea.
Tony
Peregrine Spirit
1994 E380 #16
I have done a bit of research on installing a belowdecks AP on my E38 and I am planning on using a Nexus unit. The installation will likely be a mirror image of CaptRons with the exception of the gear. IIRC, it is not a good idea to install the steering ram directly to the quadrant as the quadrant is NOT designed for such a localized load and not reinforced in that area. This has been done and the loads will actually break out a piece of the quadrant. Installing a reinforcing plate such as CaptRon has done will spread the load to multiple points on the quadrant and keep that from happening. RT
My 1981 E38 has a below deck autopilot installed when I purchased the boat. The ram and the rudder sensor are both attached directly to the steering quadrant. I have not had any problems with this installation. Several years ago I replaced the autopilot electronics (CourseMaster) with a Nexus Servo electronic controller which connects directly with my Nexus instrument server. I have been very pleased with the performance and reliability of this combination. The Nexus Servo has a learning capability such that it adjusts its control based on the performance it achieves. Down wind it often steers better than I can.
Tom
S/V Mistress
Any pictures would help , mounting of ram, attachment to rudder . Thanks allen
