I prefer to use a halyard hitch on the main. https://www.animatedknots.com/halyard-hitch-knot
Frank we have a camera and can bring it in for you.Thanks for this great idea! I've ordered one, but it won't arrive till March 4th.
So in the meantime I'll try various ways of moving the other halyards to get them out of the way, but I'm guessing the old one wrapped itself around something. Maybe the camera will show that when it arrives.
Yes ! It seems it is purely what you are personally comfortable with. I tend to lean the knot direction as I like to "renew" periodically by cutting off a few inches and or flip it end to end. UV, in my mind anyway, seems to be the biggest issue when it comes to a long term failure and I just feel more comfortable being able to somewhat mitigate that exposure.Regarding the never-ending discussion of Splice vs Knot...
I think you had said your halyard was oldish ? I'm pretty sure UV finally reared it's ugly result and the new line/splice will probably outlive the previous. What type of rope is the new halyard ?but he assured me it won't break.
Dave,I think you had said your halyard was oldish ? I'm pretty sure UV finally reared it's ugly result and the new line/splice will probably outlive the previous. What type of rope is the new halyard ?
That's exacly what I ended up with for all the same reasons. When compared with Dyneema cored lines, the cost is reasonable. My only complaint so far is the cover is a little more slippery than the older stuff we had and requires 1 to 2 more turns on the winch drum. It probably has more to do with the OD of the line compared with what my old Barriant STs were designed to hold then the cover itself. It's an easy adjustment though and I can tell the difference.Dave,
The rigger said that on examining the broken halyard, he thinks the splice was faulty, and was surprised it lasted as long as it had. The new halyard is 10 mm Samson MLX3 Blue Tracer, an improvement on their MLX line. The rigger recommended it over Yacht Braid which stretches much more. In reading about the MLX3 it sounds quite amazing (as much as a halyard can). It is light weight, strong, doesn't absorb water, very low stretch, easier to splice than MLX, etc. The rigger said it would be a noticeable difference because the yacht braid stretching a bit would make the sail sag a bit in a stronger breeze, causing scallops in the luff and deeper draft, requiring more sail trim underway, whereas the MLX3 will not do that. It is a bit pricey, at $2.50 / ft. Canadian, about $1.85 / ft. US.
No, he didn't know why it failed. He assured me that his splice on the new halyard would not fail.That's exacly what I ended up with for all the same reasons. When compared with Dyneema cored lines, the cost is reasonable. My only complaint so far is the cover is a little more slippery than the older stuff we had and requires 1 to 2 more turns on the winch drum. It probably has more to do with the OD of the line compared with what my old Barriant STs were designed to hold then the cover itself. It's an easy adjustment though and I can tell the difference.
Did the rigger mentioned how the splice failed?
