Hi,
I have an old (probably original) Jabsco Water Puppy electrical bilge pump mounted in a port hole in the quarterberth of my 1984 E30+. It has been working fine, though I have taken it apart a couple of times to replace the impellor--once took the wrong bolts out and opened up the motor part, but it looked ok and I got it back together and it's been fine.
However, lately when I raise the plastic switch in the bilge, it takes a couple of times for the pump to run, as if it was sticking; I only do this for a second at a time a couple times a week to ensure it's working. Today it wasn't working at all. I noticed that the 15 amp fuse was blown. Because the fuse broke when I tried to take it out of the in-line fuse holder, I bought a new fuse/fuse holder and wired it up. However, before I completed the wiring I briefly touched/connected the positive wires before wiring in the fuse holder to see if the pump would run--I got a pretty strong spark, but no pump activity, so didn't try that again. I was puzzled that the motor didn't run then. I also removed the impellor, thinking it might be sticking, but it looked like new, so I greased it with water resistant winch grease and reinstalled it. After wiring in the fuse holder and greasing the impellor the pump worked for a second or two and stopped--another fuse blown.
I checked the crimped connections to the fuse holder and they are solid. The wire to the DC panel looks fine and the connection there looks good. The negative wire goes under the engine out of site, but I recently cleaned and tightened all the negative connections on the engine just for good measure (weeks ago and everything has worked fine afterwards).
I don't know what could be causing the blown fuses and pump malfunction. I'm thinking an electrical short/loose connection somewhere, or a seized pump motor drawing too much current. But the connections look ok, and the pump motor did work for a second or two before blowing the fuse, so it can't be seized, I think. I debated running the pump without the fuse for longer than a second to see if it will run longer, but I know fuses are there for a reason and I'm a bit uneasy about having wires get too hot or causing other problems.
I do have a voltmeter and an ohm meter (no ammeter). I know I am getting normal voltage to the pump, but I have never understood how to check for resistance with the ohmmeter, which might tell me if the motor is shot.
In short, I have exhausted my very limited electrical problem-solving ability, and would appreciate any advice on how to determine what the problem might be, how to check the pump motor. I can replace the bilge pump with a new one, but don't want to do that until I know that the existing one is "toast" in case the pump/motor isn't the problem.
Thanks for any tips and advice.
