skipper007
Buying (maybe) an E32-2 with a wobbly rudder (And the ensuing tale of repair)
Hello world....
First post. Not yet an owner, but have contract on a 1974 E32-2 in San Fran bay. Boat is in overall good shape, but I've found significant slop in the rudder. Survey will be scheduled within 2 weeks.
I'm debating doing the rudder myself (price concession already exists). I've read every rudder post on this site, but have some very specific quesitons. If anyone can help email me - tisbond@comcast.net
The current owner has never tightened the packing. He busted a steering cable and replaced it, but didn't tighten it well. The deck mount end, where the tiller attaches, is extermely loose. From what I've read > 1/4" of play requires attention. The play on the rudder as is probably > 1/2" if not 3/4". You can grab the shaft and watch everything dance.
My questions are:
Skip<O</O
Hello world....
My questions are:
- Is there a bushing, a bearing or nothing at the bottom of the rudder post where the shaft exits the hull? I’ve read about people filling the post with epoxy, or using a torch to get the lower bushing out to replace it. Looks like a delron replacement is right, if it has one or needs one. What is on the E32-2?
- Is the packing assembly attached to a bearing or bushing or is it separate from the rudder post. Edson sells a combo bearing and packing which has to be glassed into the top of the rudder post.
- What is the inside diameter of the rudder post? <O</O
- What is the exact shaft diameter. I believe it is like 2 3/8” or 2 3/4” but I’m not sure.
- Is it possible or likely that the fiberglass of the rudder post is damaged?
Skip<O</O
