So last season I was moving a rope clutch on the cabin top and had the headliner unzipped. It happened to be drizzling out the next day after I was done, and I still had the headliner open, but all the sudden I felt a drip on me. I looked up and it was coming off the headliner. This lead me on a merry chase where I concluded the Stbd aft most screw of the companionway track was loose and the sealant had failed. Looking below, looked like the PO had added sealant to stop this leak (not good!).
Area is normally under the dodger and doesn’t see water for the whole season, so we added it to this seasons list figuring it would stay dry. However, during last season we saw a lot of deflection of the main winch during use. Enough that stress cracks were showing on the cabin top. Whoops, things are worse than we thought!
So this spring I have taken on removing the sea hood and then cutting out the bad core in the cabintop and replacing. I have now struggled the sea hood off only to find that the track actually doesn’t go into the core (that I can see) but the core is certainly damp. Even more surprising is the core only seems to be 1/4” plywood, I would have expected more thickness in this high load area.
My plan due to the curvature of the area is to just layup solid glass 2-3 layers at a time with laminating resin as the new core, but when removing the old core it is saturated all the way to the aft cabin bulkhead. What isn’t obvious to me is if the after cabin side is cored, or just a single ply of fiberglass that they then bonded the plywood to?? I believe it might be, but has anyone drilled into theirs to install gauges and can confirm this? I am now worried the damage might go beyond the overhead, and now am also wondering what to do with the last 1” of glass in the aft overhead that I need to tie into, but now has core that has to go.
Looking for opinions or strategies, or maybe even someone else who has been in a similar situation.
Also to add insult to injury, it doesn’t even seem like the hatch track could even have put water into the core…..so where is that water coming from??? We had serviced and resealed the winches 5 years ago so unlikely that is the source, and like I said, that area is dry all season long. It only sees water during spring setup and fall tear down.
