Hello, Ericson owners.
I have just bought an E27 few weeks ago...still getting to know the boat.
I noticed that all 4 cockpit drains connect under the cockpit and drain into the bilge. The bilge does not have an automatic bilge pump. I see a major problem in this setup - if it rains hard a boat will fill with water!!!!
Is there any way to make a cockpit self bailing???
I guess, I have to measure the depth of the cockpit and see if I can pipe the drains to the transom. I hope, the transom's bottom edge is lower than the cockpit floor. (This is the way my P-23 cockpit was made to be self bailing.
I had 2 thru-hulls in a transom that connected with cockpit drains.
Has anyone done anything like this already???? Please let me know.
Next time I'm at the boat yard, I am going to measure cockpit dept vs. transom.
If it's not possible to do, I would definitely have to install an automatic bilge pump....any hints on what size to use??? 500 or 750???
