I've got one of the E27s with the cutaway transom. After reading through all the threads concerning cockpit scuppers, connecting hoses, and seacocks, I was almost disappointed to find that my boat has only one cockpit scupper. But it's probably not a problem because any big water in the cockpit would have a big hole at the stern to exit through. The scupper is located on the centerline, in the depression at the bottom of the cutaway. It drains out above waterline (or at least it's above waterline at the dock).
But that one scupper does seem to be the source of a leak that I've finally tracked down. (A big thank you to the folks who suggested marking lines with chalk.) I'm attaching a photo, taken via the access panel at the rear of the quarterberth. As you can see, the fittings are in rough shape. In fact, although it doesn't show in the photo, it's possible to see daylight between the opening in the hull and the scupper outlet.
I'm wondering about a couple of things that I'm hoping the folks here can help with. First, is this the original setup for the cutaway transom boats, or the work of a PO? There's obviously no real throughhull or seacock here. Was there ever? Second, if a throughhull/seacock setup isn't necessary here, what suggestions do people have for sealing this up so that water can't get inside the hull here?
Tim H.
E27 #157
Tim H.
E27 #157
