Mikebat
In my head, the E32-200 has a compartment with a cover built into the countertop. I don't use it for anything since whatever is put in there gets wet. I guess its purpose is for disposal of used toilet paper, since you aren't supposed to put that down the head. It's big enough for 2-3 gallons of water.
I was thinking of converting it into a tank for fresh-water flushing. The through-hull for seawater intake is just a few inches away from the bottom of this compartment. I was thinking of installing a hose barb to the bottom of the compartment and moving the head's seawater intake hose to it. The tank could be filled with freshwater using the retractable shower hose just before using the head. That would also ensure no possibility of backwash from the head into the freshwater system. I'd also have one fewer through-hull.
What do you think?
What do you think?
