I need to repair a crack at the front of my keel. It appears that it has been repaired in the past. I dug out the old repair and now have a crack that is about 3 to 4 inches long 1/8 of an inch thick and about an inch deep. When I opened it up it was wet and I got a couple ounces of water to drain out. The fiberglass above, below and aft of the crack are intact. The keels bolts are all firmly in place without any signs of corrosion. So I think I am just dealing with a small fiberglass repair. I'm asking others, do you any experience with this situation? any advice ? see the two pics I have attached. Thanks
