Tank Fabrication update
Today I spoke with a local metal fabricator about tanks for boats.
He is the guy that built my custom-design fresh water tank several years ago.
Next project for us is replacing the original aluminum 14 gallon diesel tank with something larger that will fit under the same settee but will use the space a lot more completely and efficiently.
He explained that either aluminum or SS can be used for diesel, but aluminum is usually used to save quite a bit of weight. If using SS it must be done with the proper alloy rod/wire for the welding and must be to "food grade" standards.
As to life, he estimates that, as a very generalized average, aluminum tanks will go 20 years and SS about 30. The life depends a lot on keeping water out of the diesel and having a proper installation with no external moisture trapped against the metal.
We will go with aluminum in order to save weight. First I have to build a rigid plywood mockup for him, like I did for the previous water tank project.
"Just another winter project."
'88 Olson 34
