Blower Operation Rationale
The idea of running the engine compartment blower full time whilst operating the diesel has been discussed before (...here or on the one of the Ericson listservs, I am not sure).
Gist of it was that, in general, one does not do it to help or hurt the air supply for the engine, as it gulps in massive quantities, anyway. This presumes that you have a sufficient-volume air intake passage for your diesel in the first place.
Our local diesel mechanic YC member, who conducts classes through the complete rebuilding of a marine engine, advocates running the blower all the time to exhaust the hot air that: 1) collects in the upper portion of the engine compartment, and 2) is close to the alternator.
Note that this applies ONLY to diesel engines!
When our boat was constructed, the air intake was a passive hose to the top of one of the engine stringers, and the powered exhaust hose intake was right beside it.
After talking the situation over with our mechanic/teacher, I removed the "intake" hose -- there is ample square inches of air access to the stern lazeretto area where there is an outside ventilator on the starboard side of the stern combing. Then I put in new hose from the top of the engine compartment, through the "turbo blower" and thence to a ventilator on the port side of the aft combing. If you have ever seen an Olson 34, these are the stock ventilator locations.
At any rpm, a *noticeable* amount of hot air is ventilated by the blower. It actuall feels rather good on a cold day when sitting at the helm.
The blower is run for several minutes after shut down, as well.
Loren in PDX
Olson 34 Fresh Air
