E27 Pedestal Guard
ron7546
On Ebay is a pedestal guard ring item #230581325005.Do you think it would work on my E27 "YS" pedestal ? ? ?
Ron
"Bluenote"
my guess is that your YS pedistal takes a different size guard, like about 12".
OTOH, if you are starting from scratch and do not have a factory guard, then the only measurement you need to worry about is the center hole size.
You ought to check with the vendor about that center diameter and check on the attachment hole sizing referenced in the ad.
So, it might work.
ps: if this does not work without difficult mods, you might be better off cutting one out from a piece of G10 about 3/8" thick.
