I saw a early 70's boat last weekend with corrosion on the mast from where the winches had been. All 6 of the 1/4" bolt holes were corroded as was the whole area. This is the case on both port and strbd sides of the spar. But one of the holes has corroded to the size of a penny and is jagged.
The seller said that this could be fixed by riveting aluminum plates over the areas where the winches were. But I want a boat with offshore potential - would this fix compromise integrity?
Thank you
Thank you
