Your message covers a lot of different questions....
If your top speed under power is only 4 kts, you need to first eliminate some potential problem areas in the drive train. If you did indeed just buy the boat, then you know that the prop and shaft are clean, and the engine surveyed out OK. You did get a survey. Right?
If so, then look at the pitch on the fixed prop. If engine winds up to max rpm and you are going too slow, then prop is likely quite a bit under-pitched. Seems to me that your boat should do 6 kts easily under power with a clean bottom.
If, OTOH, you want an excuse to install a feathering prop, whether Max or one of its worthy competitors, you would not worry about pitch...
You set the pitch yourself on the feathering props (external adjust. on the Martec, internal and skill-intensive on the smaller Maxprop hub).
Do a search on "prop options" on this site to find a picture of our prop. A search on "prop" will bring up a lot of related Q&A.
Since oodles of older Ericsons (and most other makes of sailboats) have A4's, lots of folks on this site can comment about the "care and feeding" of those engines... And also tell you what prop they are happy with.
Sorry to be so vague, but I would approach the problem from the engine end of things, and worry about funding a Maxprop or other feathering prop (at $1K plus) only after checking out everything in front of the prop. After all, the cost of the featherer could be 10% of the price for the whole darned boat...
Best,
(who did spring for a feathering Martec for his 34 footer, and likes it)
