Ericson 30-II
Hi, My Eboat sufferred a serious failure 3 miles off of MDR yesterday when I heard the outboard rudder bumping around. I still had steering.But the lower bronze gudgeon which is permanently imbedded into "hardened epoxy" in the hull at bottom of transom had broken at the pivot point. The rudder was suspended by it's top mount / pivot and it's steering quadrant and cables. The lower bronze bushing still on the pintle. It still steered the boat effectively in the mild conditions and I made it back without further incident.
I recently rebuilt the rudder, It is a solid glass rudder, no foam. Very heavy. I fixed a few blisters, new barrier coat and new bottom paint on the rudder. Also, a new pintle bronze bushing at the bottom of the rudder. This is where the faulure happened.
I post this in case anyone has any advice on how to proceed. I have some ideas but just I wonder if this is at all common? I understand this site has some links to the original Ericson factory knowledge. Has anyone seen this before. I understand there were only some 48 or so of these E30-II's produced so there is not a large sample to look at but maybe someone has seen something similar and has an idea on how best to repair.
Thanks for your consideration.
Bregan.
Ericson 30-II, Hull 26
Bregan.
