I have recently re-powered my 1978 E32 from the old Yanmar 2QM20 (20 HP at 2600 rpm and 2.14 gearbox) to a Yanmar 3YM20 (21 HP at 3600 rpm with a 2.21 gearbox). The new engine fits nicely in the compartment but required extensive modification of the rails and a 3” shaft extension.
My old prop is marked 14X14 but has small cracks and, according to the prop shop, is bent. Performance with the old prop is as follows:
· Max rpm is 3200 (6.7 to 7 knots with fresh bottom paint..with and against the current)
· 5.5 to 5.9 knots at 2000 rpm
· 5.9 to 6.1 knots at 2200 rpm
· 6 to 6.5 knots at 2400 rpm
· 6.1 to 6.8 knots at 2600 rpm.
· The 14 inch prop clears the hull by about 1.25 inches.
· Significant vibration above 2200 rpm.
· Pull to port, increases significantly above 2200 rpm.
· I have a one inch shaft.
Speed readings were via gps. RPM were from new Yanmar tach.
I am not a racer, and after shelling out for the new engine and installation, have a rather thin billfold. No luck finding a used prop at Minnie’s or ebay. My own calculations suggest a 14X12.5 or 14X13 in a two blade. A three blade is also a possibility.
I would appreciate any help you can provide re:
· Which prop (2 or 3 blade, manufacturer, pitch, diameter)?
· Where to buy?
· How does the Martec fixed two blade compare with the Michigan wheel sail two blade?
Kirby
Uff Da, E32, Alamitos Bay, California
· Where to buy?
Kirby
