Mikebat
When I switch over to battery, the control panel for the M-25XP diesel comes on. Don't have to stick the key in. It makes the fuel pump run, which is quite annoying when I don't want to run the engine (ticktickticktickticktick), and probably not very good for the fuel pump. I do have to engage the key to start the engine though, and it runs normally otherwise. I thought it might have been the key switch shorted in the closed position, but as I mentioned I do have to turn the key to ON to start the engine, so the electrical short seems to be somewhere else.
Does this set of symptoms sound like a recognizable problem I could fix easily myself? Might need to get a diesel repair service to look at it.
