Ericson 30-II
Hi, I just pulled my transom hung rudder to paint it. This rudder seems very heavy. I drilled a few holes in it to see if it leaked any water it might have absorbed over the last 30 years but the holes I drilled were all dry and the drilled out material appeared to be wood.
I called Foss Foam and was redirected to a helpful guy named Gene. He confirmed that the rudder may be made of fiberglass clad wood but he would need to check to be sure.
From what I have read there were only some 48 of these transom hung rudder E30's. Does anyone have additional info to add? Are these rudders made of wood or are they foam filled? When I tap it with a plastic mallet it sounds the same all over.
Thanks for any help that may be forthcoming.
Bregan:nerd:
Bregan:nerd:
