I'm repainting the bottom and need to drop the mast for the marina's covered maintenance shed/hangar. They have a pulley mounted over the entrance to ease the trouble.
After digging around the different "up the mast" threads, I wanted to determine what I should absolutely do while it is down. The way I see it, there is no need to "waste" a perfectly good opportunity to do things while it is down.
So, I want to make a list of things I "should" do when it is down. Here's what I have so far:
- Lube mast track
- Clean weep holes
- Check wiring connections
- Adjust crooked antennae
- Replace broken spinnaker sheave
- Replace halyards
- Paint the Mast
What else would you consider to be a "must-do" when it is down?
- Lube mast track
- Clean weep holes
- Replace halyards
- Paint the Mast
