Hi Dagny,
I can take pictures on Friday, but it's pretty straightforward. The only big issue to me would be to cut a rectangular hole in the woodwork under the sink - size depends on the pump model. In our case, foot pump intake is T-ed into the same line that feeds the electric pump, and the pump output goes into the small cock mounted next to the faucet over the kitchen sink. We have one for the salt water too - pretty convinient, but takes a through-hull.
Regards,
Stan
I would be careful because that location is tenuous at best. What about a deck mounted pump?
I thought of installing a foot pump years ago, but felt that I'd be stubbing my toes constantly. Opted for a new electric model.
John
May be one of those hand-pumps is an option?
What about fabricating a box into the recess that you put your foot in to actuate the pump lever. This will eliminate the toe stubbing problem and also utilize your space under the sink better(if you have enough for this)
Never mind the woodwork - I know it needs TLC .
There is little chance to stab my toes with this setup - pedals are too high. They are also used by our 4-year old to get to the faucet - something that I discourage but discouragement does not work too well.
Regards,
Stan
Pump for fresh water on left , called right sided pump? They sell right & left. I need fresh water one on the left...Never mind the woodwork - I know it needs TLC .
Regards,
Stan
