Got it this far...[Fuel Tank Removal, E38]
Ralph Hewitt
Remove fuel tank 1982 Ericson 38.
Took off glass tape on portside to hull.
Will Not move? Where else is it glassed?
Mine sits in a bed of expanded foam, which I guess might provide some adhesion. Otherwise I didn't notice any more glass-in than the strip along the outboard edge.
But then I didn't actually remove the tank. Looks like leverage hard to come by.
Ralph Hewitt
Thinking about just grinding the top off and sitting/droping in a 25 gal Poly tank?
It will come out, keep at it. I'll wager the tank is just sitting there, maybe wedged in. Needs to come out, even if you have to saw it up.
I would bet on foam adhesion. I have worked around the foamed outside of our '88 ice box and that stuff is stuck on really well.
Ralph Hewitt
Thanks Loren, hard to get a Grip and leverage to make it move?
By the way we coming to Vancouver may 20th for a week after 19 day cruise from Miami through Canal to Seattle.
Maybe a day sail or lunch/dinner and catch up face to face?
Im still trying hard but 85 has slowed me a bit.
Thanks again to All that respond.
Gaviate
If it is bedded in foam, the way to free it might be a piece of thin 1/16" cable, looped under, grasping each cable end and worked in sawing fashion for at least 2/3 of length...then maybe pry loose...or keep sawing entire length. Foam is easy to cut with anything if you can get to it, and the cable will bend around corners easier than a piece of solid wire. Just an idea, I actually haven't done this.
Here's a note from somebody who did it. Mentions cutting a hole in the "quarterberth base." That apparently means just removing the plywood on top, as you have done. He doesn't report any other connections or hold-downs to deal with.
bgary
Advanced Beginner
...or, using a wire to make a slot between tank and foam, and then sliding a webbing strap into that slot so you have something to grab and lift...
llenrow
Hi
I took tank out of my 85 38 a couple years ago due to a small leak from diesel bug. After cutting away Q berth baseboard and exposing tank it came out easily It was also easily manipulated from there to stand on end in galley. It will not fit through companion way.
We took about a 5 ish gallon slice of it off the tapered small end with a metal saw and it came right out. The piece we sawed off was included the diesel bug damage so it was just a matter of patching over with good alum welder and pressure testing.
Putting back in was easy.
hope this helps
Doug.
llenrow
Here’s the pics of my 85 e38 extraction
Ralph Hewitt
Hi
hope this helps
Doug.
Thanks dug, mine will NOT move?
How did you get it to lift?
What was under yours? Holding it?
Is there any gap under the aft end of the tank?
One member used the old soccer ball trick to raise his engine--insert deflated, pump it up.
Might break the bond--and your kids must have plenty of futbols. :)
llenrow
Hey Ralph—- mine popped right out. Something underneath bonding it I’ll bet. If you look at my pics, there’s not much to that bulkhead between the batteries and the tank. I’ll bet you’d gain a lot of purchase if that wasn’t there.
Doug
