Yeah - the corner crack is well known failure point.
Ronco will suggest the B192 - which is basically the same tank - but without the 'wing' on it. You only lose about 1 gal of capacity - but you gain a storage area for um, 'related' supplies - and you won't have to worry about the corner cracking again.
I would also suggest you have them mount the elbows at the factory so they're sealed with butyl rubber, and I would have them (Ronco) also install a (vapor tight) inspection port in the top so you can hose the tank out once a year to keep the crud from building up. Gross, I know - but that nasty task once a year will keep the entire system from stinking over the long run... Also, make sure you blow out the entire system with fresh water
everyday when you get home...
See my head rebuild project in the project section for more info and pictures to see what you're up against...
Good deal on replacing the system, Tim - you'll be amazed how the um, 'character' of your boat changes (your guests will also!)...
//sse
