WhiteNoise
I have removed the hot water heater from the system. There"s a square tank that seems to me to be an expansion tank in the water circuit on the motor, I would suspect as part of the hot water system in the circuit. I am thinking of removing it also and would like to see what you guys think. Here's my logic:
I had a marine mechanic previously look at the motor after I rebuilt it. I was having trouble bleeding the air out of the system, causing random overheating. He said the rebuild was done well and the air issue is common after a rebuild. He was able to remove all the air and resolved the overheating.
He recommended I remove the expansion tank as he saw it as a high point in the system and a possible place for air to be trapped.
What do you think?
What do you think?
