All,
I'm soliciting the list for help with an upcoming potential problem. I need to screw a bunch of #6 bronze wood screws into my hull and personal history doing just that on a previous boat resulted in them snapping off as nice as can be. The obvious problem was that I tried screwing a tapered wood screw into the straight hole I'd drilled using a standard twist drill.
I have a bunch of tapered bits as a part of several countersinks that I use for making teak plug holes. Could I use one of these to make the pilot hole and expect the bronze screw to go in without snapping off?
Affirmation or other solutions welcomed.
Thanks in advance,
Glyn Judson, E31 hull #55, Marina del Rey, CA
Thanks in advance,
