Permanently remove anchor locker pan
This has been a very interesting thread to read because, like many other Ericson models, my 32-3 has a molded anchor locked pan or well. I've been wanting to install a windlass for some time now but the only practical solution seems to be putting one through the fore deck just behind the anchor locked and then kick the rode into the locker as it's pulled onto the boat. But I've been very leery about the thought of putting yet another LARGE hole into the foredeck. Needless to say that some foredeck space would be lost to it.
If I pull the anchor well pan and glass in a bottom and back to make a larger anchor well, I could reach all of the bow hardware for re-bedding, eliminate the anchor well drain hose by making the well low enough so that the water just goes out the drain already in the hull, and more important, I could glass in supports and a platform into the well that would allow for a windlass to be mounted in the locker rather then make more holes in the foredeck. Not quite sure what would be the best way to glass in and/or attach a windlass platform to handle the loads that would be experienced but I'm sure there is a way.
