James Carlisle
On my Ericson 32 I have looked high, I have looked low but I cannot find the ID Plate or engraving or stamp anywhere on the boat indicating the hull number. Please advise.
Jim Carlisle
Jim Carlisle
Jim Carlisle
I had to rely on the Hull Numbered listed on the historic Registration...
The former owner has a small racing accident which took out the transom numbers.
1971 E29.
Rick+
I read the posts about locating the Hull ID. I was hoping someone could post a picture of exactly where they found it their on their E35 in the 1969 to 1972 age range. I have just purchased a 1972 Ericson 35. But I am skeptical of the year because the transom does not have a Hull ID (could have been gel-coated over) and the keel is a full keel like the Mark 1. But the Mark 1's stopped getting made in 1969. The documentation says I have hull #46, but that doesn't seem to exist at least as far as Wikipedia is involved. Is there a registry somewhere? I have looked around the cockpit wheel mount and have not seen any numbers, but I will look harder. If anyone has pictures of where their hull ID is located in the cockpit could they share?
I'd appreciate any help on this
David
David
David
The spreadsheet I have shows the E-35-I was built in 1967 & 68 with hull numbers running from #1 through #45. If they made one more you may have it.
Stringers?Thanks everyone for their help. My boat ("Déjàlà") has a hull ID assigned by the Arizona DMV/Game and Fish. The first three letters are "AZZ" which is "Arizona Home Made Boats". The last three numbers are 272 indicating February 1972. I am still in the process of getting the ownership documentation but I live in Arizona so I will research when the boat was first registered in AZ. I am quite sure that this boat has never actually been to Arizona, but it's possible it was on a lake for a while.
As I said I am skeptical of the Feb 1972 manufacturing date as this boat clearly has a Mark 1 keel. The previous owners said "we were told it was hull #46 by the survey but we have not found any evidence on the boat to support this." The boat has been converted from the original Atomic 4 diesel to a Thunderstruck electric motor (and solar to charge the batteries). The original motor mounts are still there but there is some rust on them. I will check in that area for a hull ID, as well as on the cockpit wheel housing. Pardon my ignorance but I don't know what a "stringer" is, hopefully one of you can help out a newbie .
I am not sure of the provenance of the boat. The previous owners had it for about 10 years in California and Mexico and it was registered in both Arizona and Canada, and they mentioned one prior owner based in California also (boat was called Désiree then) but I don't know if that person was the original owner.
For some basic info, our boat is currently on the hard in Puerto Penasco in the very northern part of the Sea of Cortez. It's been in storage for a year as one of the previous owners sadly passed away. We've been getting Déjàlà ready to get back in the water and we hope to do that over Memorial weekend. I'll post pictures of the whole process, should be fun to watch.
