The lead's gotta go somewhere...
For FRP production boats, including quite large ones, there are basically two ways to get "internal ballast" into the molded keel cavity. Plan A is to have enough internal volume to the cavity so that the layers of glass and resin can be layed up by reaching down there with long-handle rollers and building up the layers. Note that this is only appropriate if the the actual hull is being layed up as one piece. After the hull is done, the keel casting, shapped like the bottom of the cavity, is lowered into place into a mush of resin and fillers, and then may have layers of roving layed over the top. Yes, I know that some builders pour lead shot into a resin mix, along with chunks of lead and rough castings. (But not Ericson, AFAIK)
Plan B is where the hull has an inward flange for the deck or has tumblehome to the topsides and needs to be molded out in two halves. Then the two are joined down the centerline. Even this method has other possible iterations -- the mold may itself be a take-apart setup with major sections that unbolt to extract them from the finished hull.
In my "B" example, the lead would still be lowered in place after the hull was put together.
There are great advantages AND disadvantages to internal ballast. Same for a bolted-on external keel. Whether you are considering damage from groundings, blistering, fairing the keel, having a deep or shallow intermal bilge area... each construction method has its peculiarities.
I have owned both types of construction over the decades, and both can be strong and durable.
The real experts need to weigh in here with "plans C and D", and whatever else I have left out, not having had my morning coffee yet.
Best,
Loren in PDX
