ted_reshetiloff
Okay I know the prop thing has been beaten to death on this site but... I am considering getting a martek folding prop and want to know if anyone would strongly recomend against it. I need a new prop as the one on the boat is the wrong size. (3 blade 16x12) I can't quite belly up to the cost of a new feathering prop. I was looking for a decent used fixed 2 blade 16x10-11 but have not been able to find one. I can get a decent used 2 blade martek folder 16x10x1 for $100 in town at Bacons. Question is how bad will the folder be under power and in reverse? Would I be best to keep looking for the fixed 2 blade 16x10? And lastly if the 3 blade 16x12 is too much pitch, which it appears to be, by going to a 2 blade do I need to change my pitch any? Said another way, I believe I should have a 16x10.5 3 blade feathering prop. Would I get similar results with a 2 blade of the same spec, or should I maybe try for a 16x12 since I am losing a blade by going from 3 to 2?
Ted Reshetiloff
1989 E 38-200
Currently named Last Mango, new name TBA...
Ted Reshetiloff
1989 E 38-200
