Rocinante33
I have always wished for a mid-ship cleat. So for my last birthday I asked for and received one of these track mounted items from Schaefer. It arrived and is very robust and well polished and seems well made. The problem is that my factory mounted toerail track has flathead screws that are not real well countersunk. The edges of the screw heads protrude a bit so that I cannot slide the cleat past the second screwhead in a long line of many screws. The old, original stand-up block (also a Schaefer item) slides across these with no problem whatsoever. So it looks like I have two choices; file the heads on all those screws down so it clears (and risk file marks to the anodized track) or, buy a Dremel tool or a die grinder and grind on the underside of the stainless cleat inside the side rails so it will clear the screw heads. Is there anything else I can do?
