Backstay trivia
Nice photo! That 2+2 main looks great even reefed down.
FWIW, our '88 had the factory Navtec BS integral adjuster. After one not-successful cylinder rebuild I replaced it with a new SailTec unit.
I do use this to tension the forestay every time we go out sailing.
One bit of trivia I learned from the rigger that put all our new standing rigging on a few years ago was to cut the backstay shorter so that a turnbuckle could be installed just above the hydraulic adjuster. That turnbuckle is normally left at full extension.
That way, in case your cylinder loses ability to hold pressure while you are at sea or on your annual vacation, you can always turn the barrel of the turnbuckle all the way tight and have enough tension to sail the boat reasonable well.
Sort of a "belt and suspenders" approach.
Best,
Best,
