My anchor locker pan stiffening project continues to grow more complicated. Removal of the anchor locker pan yielded great access to the chain locker and the underside of the deck hardware. It also allowed a good inspection of the bulkhead dividing the v-berth from the chain locker. An obvious leak in the port-aft bow pulpit stanchion has caused some softening of the top 3 inches of the bulkhead where it tabs into the port side hull. That same side of the bulkhead is discolored but appears firm as it works its way down to the chain locker floor. This doesn't appear to be a serious structural problem, but hey, what do I know?! I'm thinking of using git rot to repair the damage to the existing bulkhead and then, of creating a marine plywood patch running from the top to the bottom of the bulkhead and about 7" wide to overlap with undamaged bulkhead. I would bond this to the bulkhead with thickened west system. I would then tab the patch to the hull and bring the glass tabbing out beyond the edge of the patch so that it bonds to the original bulkhead. How does this sound? Thanks in advance!
