Randy Rutledge
I started replacing the packing for the prop shaft and intended to change the rubber tubing at this time on my 1978 E29. I started removing the clamps and realized that the rubber tubing is glassed into the prop log. Has anyone else seen this and any recommendations for the removal of the glassing to get the rubber tubing off?
The rubber seems solid but it is 30 years old and I would like to replace it with about an inch longer to give a new contact spot on the prop shaft.
