Here ya go. Found it on Google.
http://www.vicprop.com/sailor.htm
I read all their splash page information, and note that this prop will do everything except cure cancer and baldness.....
It is a fixed three blade prop with narrower blades. It should produce a smidge less drag under sail than the props with more blade area. Beyond that, their claims seem a bit, um, "enthusiastic." The reduced blade area is probably why they reccommend a three-blade over a two. After all, it is total blade area, along with blade shape, that really determines thrust.
As to reverse power and prop walk, I believe that you will find that only a feathering prop will (mostly) cure these ailments.
As in so many things in life, it all hinges on price... I admit that I could have purchased a couple of two blade fixed props for what I paid for my featherer, but then I never claimed that boat upgrades were logical uses of money... And, in our marina, solid straight-line backup power is a huge help.
If you decide to try one, check with the used parts chandleries, as well.
This is the kind of item that someone might buy and try and then change their mind and re-sell, based on their own empirical data.
Best,
Loren in PDX
