Hi Stan (?),
I'm just doing a cut-and-paste of the links which were useful for me when I did this job last year. It's a barely edited data dump with my cryptic notes, but hopefully you'll find something useful.
master-thread.9603/
p4 #61- Butyl tape x2 #69- Butyl #70- 3M 4200 #75- yellowing of 4200 #76- Dow 795 & butyl #78- 3M 4000 and new glass vinyl
Anyone know where I can get gasket of this cross section? I'm not having much luck searching online. In some cases they don't show a cross section
ericsonyachts.org
I recently removed all four fixed ports on my 1975 Ericson 25, and am preparing to clean and reinstall them after I find new gaskets and possibly modify openings. I recently watched a video of a Catalina owner demonstrating same on his 27, and noticed the window frames appeared to be identical...
ericsonyachts.org
2022 vinyl bead source
https://ericsonyachts.org/ie/threads/wanted-vinyl-glazing-for-fixed-ports-3-16-glass.19511/
Still working on our "Never Ending Project" of refurbishing our E-32 Mk II ("CaryOn"). We're currently replacing all of the rubber seals on ALL of the ports. The smaller ones went fairly easy (not really) but the larger ports/windows are a REAL problem on the small hard radius corners. The...
ericsonyachts.org
#1 fixtures for clamping #2 soap for gasket insert lube #7 silicone grease or glycerin lube #9, #10, #13, specific gasket vendors #24, #27, #32 advocates for mechanical removal from molecular level #26 Silicone Solutions remover #29 DeBond and Remov-It worked well
A year ago I had to postpone this project due to a catastrophic knee injurry. Well, the MCL is better than new, the ACL has been replaced, the cartilage trimmed, I'm rehabbed and got onto finally doing the project. The two fixed ports on the port side are out, the frames are apart, the glass...
ericsonyachts.org
In my quest to refurbish or replace my portlights I came across this company that fabricates marine and RV windows. Does anyone know of them or have any experience with them? I was thinking of sending them dimensions and having them give me a quote on their 1200 or 1250 fixed portlights...
ericsonyachts.org
Getting the outside screws out isn't too terrible. But there are two sets of two screws inside of the frame which are a real PITA. The biggest problem is that I can't even get straight access with a screwdriver. The screwdriver has to go in at an angle and not have a good fit on the screw...
ericsonyachts.org
#26 cleaning regimen, D795 instead of rubber gaskets, use special tool #34 No butyl, 4200 is too strong, instead 3 choices #35 4200 may damage some plastics
I thought I’d share my experience of rebedding my portlights on my 1977 Ericson 27. To more or lesser degree all portlights leaked. On the exterior, PO(s) smeared silicone around the frame, and on some cases along the glazing/gasket connection...
ericsonyachts.org
Hi All, Hope everyone is doing well! I wanted to reach out and get some expert advice on how to fix my leaking portlight. About a week ago we got some heavy rain and I noticed a very small drip coming from my portlight. The leak seems to be coming through the area between the glass/acrylic...
ericsonyachts.org
Bomar not rebuildable
https://ericsonyachts.org/ie/threads/bomar-opening-port-lights-circa-1985.11670/
The opening ports on Thelonious were by Bomar. They were mechanically sound, but the lenses looked like Lebowski had dropped a bowling ball on them. In addition to cracks and crazes, they were fogged. Bomar lenses, unfortunately, cannot be...
ericsonyachts.org
2005 paint frames veneer etc.
https://ericsonyachts.org/ie/threads/opening-portlight-removal-and-replacement.2502/
I hope you all will bear with me... There are many threads on this site on this subject, and I've been involved with them. Also, most of the info gleaned from those threads have been immensely helpful. If this info is way old news, my apologies, and disregard! I was describing the...
ericsonyachts.org
2008-9 caulk v butyl
We have gotten to the point of digging the fogged plastic lenses out of the aluminum frames. We removed the frames because they held the laminate to the cabin side. The flange goes through the cabin side from the inside out, with an aluminum piece that matches all around the flange on the...
ericsonyachts.org
mostly cosmetic
On my 1972 35-2 the portlights were leaking, and faced with the choice of seeking out the leak or pulling the portlights (boat windows) and repairing, or buying new portlights, I chose to pull and repair the portlights. To replace was gonna be around $3,200, while reseating and repairing under...
ericsonyachts.org
#1- Smooth-On 01022 A4 Metalset
Does anyone know where to get a gasket that fits between the glass and frame for a fixed portlight an a Ericson 35.Iwill be repairing a leaking window soon . Any suggestions greatly appreciated:confused:
ericsonyachts.org
Hi, I have one portlight on my E35-2 1978 leaking through the gasket around the glass. Any suggestions for a supplier? Thanks Chris Cook
ericsonyachts.org
link for gasket co
I have a small leak in one of my Lewmar portlites and have removed it to reseal it. I am very reluctant to remove the two small screws, separate the frame and remove the glass and gasket, I fear I will not be able to get humpty dumpty back together again. Much to my surprise, I was able to...
ericsonyachts.org
Greetings All, I have been tracking down replacement gaskets for my Lewmar operating ports. I've talked to a couple of Lewmar retailers who ended up referring me to Lewmar to work out the size I need. After going around with them I am informed that Lewmar made a custom size port for...
ericsonyachts.org
Hi everyone! I am sure somewhere back in time this has been covered. I am new on here and we just got an E27. The portlights have corrosion and have been dripping for quite some time. I have seen conversation on just about every model but the 27 specifically. The owner's manual says they are...
ericsonyachts.org
Heat and Alcohol for sealant cleanup, esp when uncured
PORTLIGHT GLAZING VINYL
CRL Glazing Vinyl; 11/32" Channel Depth 9/32" Metal Opening for 3/16" Glass - 100 ft Roll, D752C, C.R. Laurence
www.technologylk.com
Catalina Direct, publishers of the Catalina 22 and Catalina 25 Owner's Handbooks and the largest supplier of parts and Lewmar winches for Catalina Yachts in the country
www.catalinadirect.com
CUSTOM NEW PORTLIGHTS
If you're new-ish to the site, you might find @ChristianWilliams master thread list helpful. I couldn't find it just now, but someone will be able to direct you to it.
