I'd be hesitant to switch to an outboard on a small boat if you are ever going to motor in steep chop. My 27 had an outboard on it when I bought it (the seized A4 had just been removed). I knew that I was going to repower with electric so I figured the outboard would be fine temporarily. In most conditions it was safe, but in steep chop the prop would come out of the water then the head of the motor would get submerged - over and over. Very scary. If you can keep your prop under the boat (inboard), do it. Another issue I had with the outboard was the prop coming out of the water when someone walked to the bow - like when you are coming into a harbor!!
