Replacement Rub Rail
Stuphoto
I will see the post office tomorrow and ask about the dimensions.
And should have it in the mail by Tuesday.
Unless you are in a hurry I will just send it via regular post.
Stuphoto
Nice to see the rubber insert still available, DLM Too bad they don't have the rest.
I guess with a 50 year old boat, we shouldn't expect to find everything readily available and on the shelf of your local marine store.
Before just deleting mine I was seriously thinking about just getting some nice long tight grained yellow cedar milled up. A strip cut in the length for the seam. Then steam bent it along the entire length.
gareth harris
I got rubber a replacement for the track as well as the rubber rub rail itself. I think they both came from Wefco but it was back in 2005. I would imagine the E35 of the era used the same design as the E32, and probably the E27 too.
Gareth
Freyja E35 #241 1972
Touchrain
Bought both items, base and insert from Wefco a couple years ago. Not cheap, but performed well. Base is now a rubber material, rather than the brittle plastic (after 40+ years). Make sure you epoxy fill old holes in hull and use plenty of sealant. I know from experience. Otherwise you’ll find the leaks inside.
Also fill any voids in the flange between hull and deck. Owners have reported leaks, very mysterious in nature, that turned out to come through rub rail screw holes or localized separation of the flange.
Yes, the Ericson deck/hull is reinforced inside with roving, making the joint stronger than many era counterparts, and we have no reports in all the history of hull/deck failure (unlike other designs).
However, water can work its way through voids in the roving, or screw holes drilled through the roving. So seal the flange and screws, and thanks to the member investigators who discovered and documented this phenomenon.
Typical gap in deck/hull flange
Pkroha
Hi Stu, No not in any hurry, regular post works. Just send me an address to send some money for the postal fee. Thanks again for the help.
Curt KC
I called Wefco who said the insert is only available in black due to the white being too difficult and expensive to work with. I'm not keen the idea of changing it though I suppose I could get used to it if I had to. If you got the black do you have any pics handy?
DLM-E30
I got the Black insert, but have not installed it yet. Boat is currently hauled out for through-hulls and paint. I think it's gong to look fine, but I would have preferred the white.
Dave G.
1984 E30+ (SOLD)
Yes I agree. Also thought grey would better than black. But my suggestion to Pete @Wefco(for grey) has not produced any result. Apparently white is very difficult to keep clean in the molding process.
Touchrain
I got gray. Its fine. Needed some cleaning.
PANorth
The 1982 E38 that we are refitting has a teak rubrail. It had a section broken out when we started about 1 1/2 years ago. We asked a cabinet maker, who had all the right tools, to match a new piece from the old one. He made enough to replace the rubrail nearly all the way around because that was the smallest piece of wood he could get.
SJ Sirota
I still have the rub rail I removed from my 73 25'.
If anyone knows if it is the same I can probably cut a section as long as you wish.
Sorry for the bad photos. View attachment 46880View attachment 46881View attachment 46884View attachment 46883off and mail it to you for therubrail channel cost of shipping.
Most of it is in decent shape, where it wasn't sitting on a rock.
Stu,
Do you have any more of the used rubrail channel? I have a 35 MKII that was damaged in a storm. I lost 2 feet of the channel and am looking for a replacement section.
p.gazibara
I thought about cutting the flange off and just glassing over it, would look more modern and prevent any future leaks. Big job though, so I never got around to it.
There is an Ericson 34 (2) in Portland that had a local yard glass in and repaint the adjacent topsides, about 20+ years ago. Still looks pretty good. It's now for sale so you can see this work in some of the brokerage photos.
klb67pgh
I wasn't sure if I should add to this post or start my own. If the latter, my apologies. I have been researching options for my chalky white rub rail on my E25. I confirmed the factory Wefco rub rail insert is no longer available in white - only black, since COVID. The channel is also black.
I had AI generate a picture of my E25 to try to imagine replacing the white rub rail with a new black one. It’s not perfect and I couldn’t get the AI to lower the rub rail down to the cove stripe or make it thinner, but you get the idea. I don’t love the look.
I researched some other possible suppliers, including getting a sample from Catalina that I hoped would be close enough – no luck. The samples I got from Taco also didn’t work. As of now, I am aware of no other white or grey rub rail that will work with my factory channel. My factory channel is in great shape save about 3 inches where it looks like the boat hit a piling before I bought it in 2020. I was planning on just living with that imperfection rather than replacing the full channel.
If anyone in this post still has a leftover piece of the grey channel - please message me. I'd love to have it.
I am now tempted to try white vinyl buoy paint to see how that will hold up. I decided I'm done getting chalky white stuff from the rub rail this season. I'm just not sold on a black rub rail on this boat.
Kevin
Mark F
Kevin
I used some white buoy paint on my chalky deteriorating rubrail and it is holding up really well.
Dave G.
1984 E30+ (SOLD)
Yep, I had the same issue after looking at the black option, not good. I also had the same "chalk" problem. I ended up scrubbing the it with a scrubby sponge(s) real good and then using an automotive vinyl/plastic cleaner sealer product that actually worked pretty good. It also has UV protection which I believe is what causes the problem. This is what I used but I'm sure there are other brands out there.
